mary moon
Posted on - 08/24/2011
I want to know how can i connect my laptop with TV and connect my TV to my laptop please and i don't want any errors happen and is there away to publish what is in TV online in the site or internet
Thanks for who read and answer these question
How to connect my laptop to a TV
Good Day Mary,
The answer to your question depends on the following conditions:
Does your laptop have a TV card?
Does your TV have an extension to connect it with a laptop?
If both of the above conditions apply to your systems then you can surely connect it with your laptop according to your own choice. It will work perfectly if you want to use your TV as a monitor or if you want to use your laptop as a TV. All you need is to install the concerning software accordingly and without any error.
I hope this will work for you.
Thank you
