Daan Gates
10 points
Posted on - 08/29/2012
I am learning graphic designing. I am very much interested about creating emoticons. I want to create emoticons for blogtv. Please send me some tips regarding blogtv emoticons creation secret. Please also tell me how to send the emoticons to blogtv.
Want to know the secret of creating emoticons for blogtv
As new graphic designer, I suggest that you use design application that are user-friendly. Try first to follow some easy and basic tutorial that can be search thru internet.
There is no big secret in creating emoticons for blogtv just be creative yourself and design original ones. Different kinds of emoticons required different file formats. Still or non-moving emoticons should be in png format, while moving emoticons must be created in swf formats. Image resolution should be between 18-20 pixels only.
You can submit your emoticon original designs directly to [email protected]
