anonymous
7060 points
Posted on - 09/01/2012
I am using bijoy bayanna software in my pc. i write both English and Bangla by using this software. but it is very boring full for me to click everytime on bijoy icon to convert unicode to English or vice versa.
have any shortcut key is available to convert from one another shortly?
annes
Want to know shortcutkey to active bijoy unicode to English
There is an easy way to convert unicode from English to bangla and vice cersa. You have the option to press Ctrl + Alt + E or Num Lock on your keyboard if you wish to use the English unicode and if you wish to switch back to Bangla, just press Ctrl + Alt + B.
I read your message, and I also used this software, but I have changed it so there aren't any problems. If you make mistakes while writing, you just need to press Ctrl+Alt+B and it will translate English to Bangla and Bangla to English.
