Want to know using Skype in Linux
Hello everyone, I am using Skype in my Linux. Â
Now I want to install Linux Skype auto dialer freeware.
Is it supported in my PC?
 Please give some strong comment,
Hi there,
Just like any other Operating Systems (OS) Skype features and services are readily available even when using Linux OS.
All you need to get started is to find Skype for Linux. Freeware like Linux Skype autodialer freeware that goes along with the Skype for Linux are supported application that may run in your Linux run gadget.
Regards
Just similar to any other (OS) Skype type and services are available even when using Linux OS. All you need to get started is to find Skype for Linux.
Linux Skype auto-dialled freeware that goes along with the Skype for Linux are supported application that may run in your Linux run gadget.
Hopefully this is will work.
