Want to know which metro pcs phone allows Skype
I m planning to buy a metro pc phone but I m not sure whether which of them supports skype audio/video calling. I need skype must, so please tell me which metro pcs phone allows Skype?Â
Good day Coshuan
Yes Skype are supported on some of the phones.
The Huawei Activia supports Skype audio and video calling .
The LG connect is technically not supported but it works for audio and video.
The phones below support Skype but it`s not clear if it support audio and video.
Skype is compatible with this phone because the OS is Android.
Another phone is the LG Optimus M+.
Skype can run on any Android Phone that has Android 2.1 and higher.
Skype is also with Symbian OS versions:
All 4G phones that are sold by PCS Metro Provider support Skype calls. When Microsoft bought Skype, they made it available for 4G network. Calls are free if you are in Wi Fi area, and make Skype to Skype call . If you, however, call a mobile phone, using WI FI , it is also free for USA or Canada, if you are using Skype.
Hope this answers your question!
