I m trying to find out why SSL VPN on mac OS stops working, there are also some issues regarding the configuration of SSL VPN on mac OS.
Can anyone tell how to solve this problem and make SSL VPN work on mac OS?
Want to know why ssl vpn Mac stops working
Hi Amanda!!
Your question is very important to all. I have explored the perfect solutions.
I am giving the instruction by following which you can overcome the problem.
You should download the latest version of Tunnelblick.
Copy the Ace VPN configuration files to Library/Application support/Tunnelblick/Configurations.
Run Tunnelblick and connect to acevpn-premium-udp-faster or the configuration of your choice .
Enter your user name and password when prompted.
Then start using the application.
Thanks
Nowell
