Want learn mapping in oop.
I am new in programming. I want to know mapping in OOP. Kindly tell me a simple and easy way to learn my mapping oop. I shall be very thankful to you.
Hi Deborah,
Basically object oriented programming is very easy but some technical. The basic advantage of object oriented programming is due to classed you can save your time it is easy to read and write and maintain. If you want to reuse your code you can also reuse your code and can save your time to write lengthy scripting. I want to suggest you first you should to do practice about classes, parent classes when you will perfect in creating classes so you will able to write source code in object oriented programming.
Hopefully this instruction will help you.
Thanks,
Raun Nelson
Notifications
