msmunir
Posted on - 09/20/2011
I have internet download manager and am very happy with the increased internet speed but it's the trial version. My version is IDM 5.18. and within 7 days it will cross the time limit.
I've heard if I get a patch, I don't need to register.
How can I get this patch?
Want patch for IDM 5.18
Since your software is in an expiring state, this would only mean that it is in the trial version and programs in this state really have limitations and most of the time expiration period where the software literally stops working at the end of the period.
But there is always a workaround on this. Sometimes reinstalling the software would do the trick but this doesn’t always work.
There are applications that can’t be reinstalled when it reached its expiration period. Even if you tried reinstalling it, it would always turn out to be expired after the installation. But this is not always the case. There are still others that can be remedied by simply reinstalling the software.
Try this method and see if this works on you and possibly reset the expiration period of the application.
If this method can’t fix the expiration problem then simply buy the software by visiting Internet Download Manager Internet Download Manager 6.12.
This is by the way the latest version.
