Hello fellows,
What is the best software that can perform for a frame for frame video conversion? I want to download a free and safe one to avoid any errors in the future such as crashing software and unsuccessful rendering of videos.
Regards, Gregory.
A want to perform frame for frame video conversion.
Hi. I tried searching for softwares that can carry out a frame-by-frame video conversion. But unfortunately, most of them are not available for free. However, I found this website: http://www.virtualdub.org/
It might not be as powerful as adobe premier, but I'm pretty sure it can do the trick.
Hope this helps.
Hi Dear
you should use Ulead Video Editor, It is a Power Pack software specially designed for the Frame by Frame Videos.
Using this software you can remove unwanted Frames from your video. and sometimes you can make some frames more better by manipulating them, like apply special effects on it. Make more brighter Darker etc.
This is the best Software ever for frame by frame Video Editing. you can download it here.
http://download.cnet.com/Corel-VideoStudio-Pro/3000-13631_4-10029706.html
Enjoy,
BaberZaman
I will suggest you to use the Magic Video Studio which can help you in editing your videos. It can help you capture videos, convert it and then burn with a DVD. You can download the trial version from the link below:
Thanks
