Want to read sata bad sector table
Hi everyone,
 I am using sata hard disk  on my PC.
I want to read sata bad sector table cause I am facing some problem.
Is there any software on it, please let me know.
Thanks.Â
Hi everyone,
Thanks.Â
Hard disk drive is an integral part of every computer. It stores all your information. One of the most prevalent defects of hard drives is bad sectors on a disk surface. Bad sectors are a part of the disk surface which contains not readable, but frequently necessary information. As a result of bad sectors you may have difficulties to read and copy data from your disk, your operating system becomes unstable and finally your computer may unable to boot altogether.
When a hard drive is damaged with bad sectors, the disk not only becomes unfit for use, but also you risk losing information stored on it. The HDD Regenerator can repair damaged hard disks without affecting or changing existing data. As a result, previously unreadable and inaccessible information is restored
There are some software, Which can be helpful for Hard Disk Bad sectors problems. You can download these from here:
1. http://www.sharewareconnection.com/software.php?list=Repair+Bad+Sectors+Sata+Hdd
2. http://www.fileguru.com/apps/repair_sata_bad_sector
Try These software’s.
Dear Chad Brown,
Bad sectors are very dangerous for hard disk and data. In face when we restart our computer consequently or met with accidental shut down, then it makes some bad sectors on hard disk.
Bad sector is a scratch on surface of the hard disk. You can recover these bad sectors very easily.
Here I am going to tell a bad sector recovery utility, try this utility for better results.
Hard disk Bad sector remover 2.0 version, it will remove bad sectors without losing your data. You can download it from this link.
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Bad-Sectors-Repair.shtml
I hope it will help.
