Joe Adam
Posted on - 08/25/2011
I have installed avast antivirus in my PC and i found that Trojan horse has gone into the system and creating late boot up so please tell me ways for protection of machine from the same and remove Trojan Horse from my computer.
How to remove and protect my machine from Trojan Horse
Hi Joe,
There are some ways that can remove a VIRUS. But in this time i will show you on how to remove a virus without using software.
I bet that you know where the command prompt activate. If not, just follow my instructions.
Go tot he START MENU in your desktop.
Click and type "cmd" on it.
One's your in the command prompt.
Type "cd.." for many times.
Now type "attrib"
This will navigate you thru the systems that function.
The virus can be detected By its name. Please REFER IT BELOW IF YOU GOT THIS MESSAGE WHILE ATTRIBUTING.
" AUTORUN.inf "
" xxxx.pif "
While doing this prompt. You will now have the idea on which are the virus. THEN PROCEED.
C:>attrib -a -s -h -r      then enter.
C:>del "autorun.inf ,       ENTER
C:>del "xxxxxxx.pif"Â Â Â Â Â Â Â Â Â enter
This goes same as DRIVE D: (if the drive d has "autorun.inf and .pif"
D:>attrib -a -s -h -r       then enter.
D:>del "autorun.inf,       ENTER
D:>del "xxxxxxx.pif"Â Â Â Â Â Â Â Â Â enter
Then run the prompt "cd.." to each DRIVE again to see if the VIRUS is remove. If this is working. Then your luck is good.
BUT IF NOT. You need to REPROGRAM it or REFORMAT the OS.
This is a SAMPLE:
Hi there,Â
Avast is simply a pile of waste.
Very sad to say that Huge loads of Malwares and or Viruses are Playing with your system. You must be very careful while using External devices to install Softwares and other stuffs and also while using Network. Its really horrible and tough to fight with viruses and only a PC expert geek could do remove SOME of the common viruses .Better install a GOOD Antivirus and or Internet security.
I personally Recommends Kaspersky Internet Security 2012. It works great. It catches almost all the viruses and also very smooth to operate. What problem kaspersky has till its 2011 versions was slow updates. Now they have solved the problem.
Go try download the trial version and try it for 30 days and if and only if you liked then buy the license for 1 year.
