F Samuel
10 points
Posted on - 07/20/2016
Hi everyone,
Cloud Computing has made Access to Files very easy. I can use it to send large files to other users. I have encountered a need to share a same file between many users. The idea is to upload the file to the cloud. But, which will be the Best Free File Sharing Sites?
Want To Share Data Using The Best Free File Sharing Sites.
Google Drive will be the best site for you according to your needs. You can create a general account for all the users. After that, you can upload the File to the Drive.
The user who would want to Access the File may log in using the common Login Credentials.
This method reduces the pain of transferring large files to different users one-by-one by limiting the transfer to take place only once.
