Want a single chip driver free for webcam
I had a single chip driver which was lost. Now I am looking for a single chip driver for free for my webcam. Where can I find the free single chip driver?
Hello.
You did not mention your operating system.
The search could have been easier if you had mentioned your operating system.
Well, not a problem. I have found a website where you can get single chip driver for free for your webcam.
Click on the below link to download single chip driver compatible for windows, Linux, OS X, and other Unix like operating systems.
http://www.driverguide.com/driver/detail.php?driverid=736507
Thank you.
If you simply want a driver for your webcam, visit your webcam manufacturer’s website then search for your webcam model there. You need to provide your webcam model number or serial number to do this. It should give you a list of possible drivers you can install for your webcam and the appropriate operating system they support. If you are using Logitech webcam, go to Logitech Support.
Enter your webcam’s identification numbers or the model number on the search box and then click on the search button or press Enter. It should show you the appropriate driver for your webcam. Also, select your current operating system for the download. On the other hand, if you are using a generic webcam with no specific brand or manufacturer, you can use MyCam Webcam Software.
It is freeware and you can use it to record videos and take snapshots with your webcam. It supports Windows 2000, Windows 2003, Windows XP, Windows Vista, Windows 7, and Windows 8. Another free webcam software you can try is ManyCam. Go to Download ManyCam Free Webcam Software to download. The latest version supports Windows 7, Windows 8, Windows 8.1, and Windows 10.
It requires Intel Core i3 or faster processor and 2 GB RAM. For Mac, it supports OS X 10.9 Mavericks and up.
