Want the solution regarding Nokia X2-00
Can i find the delete call history from my mobile Nokia X2-00?
If possible please suggest me as soon as possible.
Of course you can delete the call logs in Nokia x2 just go to call history list.Â
Select the call you want to delete from history by holding down your finger on it then a menu then gives you the option to delete and there you go brother.
It has been reported that Call History cannot be deleted from Nokia X2.Â
It is a S40 Mobile i.e Java Based. And Nokia had reported that it support OTA (Over the Air) firmware update.Â
However, you can delete Call records by going to menu then log and then click Options and then Select All then delete.
It'll help, in case it doesn't work. You'll have restore your mobile to factory settings, just go to menu, then settings then restore factory settings.
It'll ask for Settings only or All settings,Â
In settings it'll restore all Mobile Settings like Themes, Wallpaper, Call records etc to default. in other case it'll erase all your data and restore your cell to Factory settings.
If you won't be able to get your desired action i.e.
Call History removal, check for updates.Â
You can do so by using PC via Nokia Ovi or through OTA (it'll require Internet Data downloading).
Go to Menu then setting then Phone then Phone Updates.Â
