Want source code of SQL convert to php
Hi everybody,
I want to put a date and time on my server through PHP coding. I have a SQL code for putting the date and time. That is why I need to source code of sql convert to php language. Is there any way to convert SQL code directly to PHP?
Best Answer by Gillam Janetj
Answered By 0 points N/A #198174
Hi.  Wallace Browning,
I got your problem and well,creation of a PHP date in format for sql timestamp insertion will need  to use 'sqlnow()' function.
I have tested it myself and its all working good. So, I will recommend it to you too.
Please try those steps outlined in this link and you will obtain what you are in need of
I hope that this will fix your problem
Thanks & Regards
Gillam Janetj
Answered By 0 points N/A #198175
Here I am attaching a code to solve the problem "Want source code of sql convert to php". Follow these steps:
1. Open Notepad from Start ->Programs-> Accessories.
2. Type the above codes into it.
3. Save it.
4. Now open any Browser such as Internet Explorer / Mozilla Firefox etc.
5. Click on File->Open->Browse.
6. Select the filename.
7. Click Open.
8. Click Ok.
Your code will be executed.
Pattrickk White
