WilsonJames 0 points N/APosted on - 04/02/2019
While passing by a store in the mall, my eyes caught this phone on display. I went in and asked for the price and a little bit of hardware specs. Need some hardware specs for this phone so I can compare it with the details from the sales agent. If the information he said were correct then I can come back and buy that phone.
If you are referring to Motorola One P30 Play then be prepared for some negative feedbacks from users who bought it. Anyway, the Motorola One P30 Play is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies.
It was announced to the public on August 2018 and released on October 2018 measuring 149.9 x 72.2 x 8 millimeters and weighing 162 grams. It uses nano-SIM card and available in single SIM and dual SIM models with splash resistant feature. It has LTPS IPS LCD capacitive touchscreen display with 16M colors at 720 x 1520 pixels screen resolution protected with Corning Gorilla Glass.
It ships with Android 8.1 Oreo upgradable to Android 9.0 Pie; Android One; or ZUI 4 (China version only) powered by 14 nm Qualcomm MSM8953 Snapdragon 625 chipset, 2 GHz Octa-Core Cortex-A53 processor, and Adreno 506 GPU. It supports microSD expandable up to 256 GB. It runs on 4 GB RAM with 64 GB internal storage.
The primary camera is a dual camera featuring panorama and LED flash: first camera supports 13 megapixels with f/2.0, 1.12µm, and PDAF; second camera supports 2 megapixels with f/2.4, 1.75µm, and depth sensor. Both supports 2160p video recording at 30 fps and 1080p at 30/60 fps. The secondary camera supports 8 megapixels with f/2.2 and 1.12µm. It supports 1080p video recording at 30 fps.
It has 3.5-millimeter jack with active noise cancellation with dedicated mic and Dolby sound; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, and hotspot support; Bluetooth 5.0 with A2DP, LE, and EDR support; GPS with A-GPS, GLONASS, BDS, and GALILEO support; NFC; FM radio; and USB 2.0 Type-C 1.0 reversible connector. It has built-in rear-mounted fingerprint, accelerometer, gyro, proximity, and compass sensors.
It runs on non-removable 15W fast charging Li-Ion 3000 mAh battery. It is available in black and white colors.
1....
