Want To Know How To Get Microsoft Malware Protection
I am getting some issues in using Microsoft apps on my laptop and Lumia phones. I think some malware had affected my system. How to get Microsoft malware protection?
Microsoft can get attacked by malware as it is very common for viruses and malware to enter a system and attack it. But we can get malware protection for our system. To get Microsoft malware protection, use windows defender. Windows defender is used to protecting our system from malware.
In your windows phone or Windows 8.1 operating system, enable the windows defender in order to protect yourself from malware. Sign up in windows defender and enable it so that it can search the areas which are more prone to malware. Then you can remove either the sources or troubleshoot them. This can help you in protecting your system. You can also use any use any other anti-virus for the system.
If you think your computer is infected with a virus and you don’t have any antivirus program installed, the first thing you should do is to scan your machine first with a virus removal tool before actually installing an antivirus program. Download Sophos Virus Removal Tool and install it. Once installed, start Sophos then wait until it is finished updating the virus definitions.
When starting the program for the first time, it will automatically update its virus signature database. When the program is ready, click “Scan” to scan your computer. The program will scan everything on your machine including devices connected to the USB ports. When a virus is found at the end of the scan, remove the virus and then repeat the scan until it no longer detects a virus.
When the machine is clean, you may now install an antivirus. If you want an antivirus program from Microsoft, try Microsoft Security Essentials.
