Want To Know How To Make A Network Server
I want to open my frim and want to keep all my data connected to the network server so that all employees can access it. How to make a network server?
Network server connects all your system through the network and helps you to store all the data over the network and share it when you need it. You don’t need to ask someone before accessing the files if they are kept on the server. Steps for how to make a network server are –
1.) Click Start > Settings > Control Panel > System. Go to network identification tab and click properties option.
2.) Click domain, fill on the asked specifications and click OK.
3.) Set up a username and password and click OK. Restart your computer to configure your settings.
4.) Also, make sure that you are connected to LAN and if not, then set up the LAN settings to keep your network server connected.
