Want to use brochures Linux in a simple way
Hi everyone, I am using Linux & I want to use brochures Linux in a simple way. But I can't understand it, please give me some tips in details about it, thanks.
Hello
I don't quite understand what you need. If you want to make brochures in easy way then you can use Libre Office Writer or even bette Scribus. Scribus is written for making newspaper, brochures etc. It's really easy to use and is free (like most stuff on Linux). You can find many video tutorialy on You Tube which will guide in making professional brochures.
I hope I helped you. Regards.
You may want to make your brochures using Open Office Templates. It is very simple to use and has many templates to choose from. But if you want  a more polished and professional looking brochure, I strongly suggest Inkscape. It has very good user reviews, simple and creative. It works in Windows and Linux environment .You can download Inkscape at the link below:
