karengsam
10 points
Posted on - 04/27/2013
I have been having problems using a CMS for websites created with NetObjects Fusion.
Can you tell me how to effectively and easily use a CMS with this?
And which CMS is the best to be used with websites created with NetObjects Fusion?
Thank You.
Want to use a CMS for NetObjects Fusion website.
Hello Karengsam,
NetObjects Fusion (NOF) is a wonderful web design tool as like Dreamweaver. You want to know which CMS is the best to be used with NetObjects Fusion. There are two CMS are popularly used such as CushyCMS, SurrealCMS with NetObjects Fusion. But I suggest you to use CushyCMS for your websites. You will know how it is effectively and easily use a CMS with NetObjects Fusion if you visit these below links.
1. CMS with CushyCMS -From this you will get how to use CMS with CushyCMS.
2. NOF Tutorials full – From this link you will know more about NetObjects Fusions.
3. Tips & tutorials for NOF -From this link you will get tips and tutorials which is necessary for you.
I hope that you can reach your goal.
Thanks
Taylor Delapena
