Want video editing software for free using mouse only
I want a video editing software that will be free and can be used only by the click of mouse. Is it possible to edit only with the help of mouse? Please help me out by your suggestions.
If you are using Windows XP, you can always use Windows Movie Maker. Aside from creating new videos, you can also do video editing there by just clicking.
If you are using Windows 7, you can try using VideoPad Video Editor. It is a video editing software that is very useful for creating and editing videos. It is free for non commercial use. Similar to Windows Movie Maker, it is also easy to use and only requires clicking. You can download it from this link http://www.nchsoftware.com/videopad/index.html
Hope this helps. Good luck.
Video editing software’s allows you to edit video. There is much freeware software which help s you to edit a video with professional interface. You can find them easily on the net and use it as you want. Xilisoft video editors, AVS video editor, Microsoft movie editor, are the best of them. Some more for you-
1) Avid free Dv
2) Wax
3) Xilisoft
4) AVS
5) Blender
This software’s are easy to use. Smooth and fast, you can try.Â
Fantastic solutions, my friends, and also thanks for the useful suggestion. Clark Henf, your comment was very reliable. I knew about the VideoPad Video Editor, but I didn’t know how and from where to download it, or how to use it. Your comment and the link you provided helped me to get this for my Windows 7. At present, I have downloaded this software from this site, and I am amazed at how awesome it is. With a simple click I can create and edit my videos easily. Thanks again, my friend.
