I would like to know the top 10 of pc cleaners to remove malware, spyware etc. Please advice me! Also I will be thankful for the information of using them from your own experience and if there are any problems can arise with the using of this software? Errors, troubleshooting etc.
Wanted top 10 pc cleaners!
Hi Lucien A Nieves,
Keeps your system in perfect shape. It has a memory Optimizer, junk file cleaner, registry cleaner, anti-spyware tool among many other features. Its free, easy to use and friendly interface.
It keeps your PC optimized to keep its speed in tip top status. It also helps in removing browser junks and cluttered files to keep your system running smooth. The drawback is it is a trial version.
This software can clean temp files, log files, recycle bin, and many more. Its fast and powerful. Its also more like ccleaner and its free.
With time passing, pc will always slow down. With AusLogics BoostSpeed it can lessen startup and shutdown time. Its more inclined in optimizing the speed of your computer. Its also in a trial version.
It has proven its powerful performance. It can correct the registry items. Backup and restore registry and many other features. It is also a trial software.
Its gives a detailed view off your system. And has many features like, a real time view of HDD, SSD, RAM. Resolves issues like viruses. Costs $28.
Its a faster cleaner yet powerful. The main Features are Registry cleaner, duplicate file remover, remove corrupt or leftover registry entires, schedule feature and many others.
CCleaner is another powerful cleaner. It has a user friendly interface. It can scan and fix registry, clean your pc, browser and you can also uninstall programs and manage your startup items. Been using it for a long time and its really good. Its also free.
This software can detect and remove adwares from your computer. It allows to check problems with a click of a button, fix registry items, remove adwares and malicious programs.
Its free safe and gives a complete and quick scanning. It has registry and disk cleaning, privacy protection, wipe clutter etc. Its also has a good user interface.
Hope this list will be helpful to you.
Thanks
points
