How can I watch Youtube on my Samsung Transform Ultra Android phone? There is no Youtube app. When I try watching in my browser, the videos just keep loading. I thought it was about the connection but I guess it's not. What seems to be the problem?
Watch Youtube on My Samsung Android Phone
If you have android phone, it is more likely default that it can play YouTube video from browser. So if you are having problem with playing the connection might be the problem, But if you are pretty sure that the connection is not the problem, you may download YouTube apps from android application store using also your browser. You can download the YouTube player here
That is a good site where you can download free apps. You can download also player that you want there to play videos. Just connect your Android phone to your computer then go to that site then click what apps that you want then you can install it to your phone directly from that site.
Good luck. J
Easiest way is just download YouTube software for your android phone. Just search on Google and install it, Now experience online YouTube video without troubles
Enjoy
