fabion cole
20 points
Posted on - 01/30/2013
Hi techies,
I have been watching imam ghayth nur kashif youtube clips and some of the comments are from critics. Is there any way youtube can filter and erase the unnecessary comments from the link?
Thank you.
Watching imam ghayth nur kashif youtube
Hello Fabio,
I'm not sure if I understood you correctly but regardless, I will provide you with a solution to your problem. YouTube is the most popular video-sharing website in the world right now. Often, in videos that you are watching there are so called "embedded comments". It can be so annoying sometimes that you definitely will want to turn them off. If you want to do so, click this button as shown in this image:
After clicking on it your videos should be without any comments and clean to watch and enjoy.
I hope this helps you.
