Water Rocker on different water temperature
You would expect that with a speaker gadget that could float on water surface while playing good music would always be used in pools or other wet activities. Is it sensitive to water temperature?
Water Rocker is a waterproof speaker that can be used in the pool or when you go to the beach. It doesn't have any problems with different temperatures of water. The round shaped speaker is the only part of the Rocker that stays in the water and you don't have to worry about it because it is resistant.
Your iPhone or iPad will be protected because it will stay on dry land, on the wireless transmitter, while the ball shaped speaker floats next to you playing your favourite songs. The transmitter can be 100 feet away from the round device and it can be used also for other audio players using the 1/8 inch jack. There is also a built-in FM radio which allows you to listen to the news or your favourite music radio while relaxing in the water. These many features make from Water Rocker a very useful tool for your summer parties or just for you when you want to listen to your favourite tracks in the pool.
There is no specified working temperature limit for Water Rocker. It works in normal water temperatures and you don’t want put it on extreme temperatures. The Water Rocker isn't unequivocally for iPhone and iPod. You are able to connect to virtually any sound cause utilizing Water Rocker's 1/8-crawl jack. Since it’s a lovely day, basically connect your TV to the Water Rocker and listen to the event or the news as you chill in the pool or play with the young folks outside. In addition, there's even a constructed-in FM radio so you would be able to listen to your top pick stations. Fling unforgettable summer gatherings by giving your pool fantastic sound, one Water Rocker transmitter can underpin up to 9 supplemental Water Rocker speakers.
