anonymous
7060 points
Posted on - 08/08/2011
In my wave cam. This web cam there is some trouble. One of them, when I am on the camera it is not work.
This is so disgusting and boring. This is trouble me to work efficiently.
Now I need why happen it and how recover it.
Fix for Webcam not working problem
The problem is with your Webcam, you need to reinstall the drivers of your webcam,in fact you need to make sure that you are installing the Exact drivers designed for your webcam brand, model, computer and operating system, after successfully reinstalling the drivers check your webcam again. If the problem persists, check your port with whom you have connected your webcam, you can check that manually by connecting some other devices with it just to check whether it is working perfectly or not.
If all the above procedure it done and problem is still there, you might have some hardware problem with your webcam, check with your webcam company or replace it with a newer one.
If you have a newly purchased webcam but it doesn’t work, you probably did not install the camera’s driver. Your camera should include an installation CD. Install the software from that installation CD and your webcam should work. If the installation CD is no longer available, you can always download it from the manufacturer’s website.
On the other hand, if that is a generic or unbranded webcam, you can use ManyCam instead. Just download and install and it should make the camera work. It works on any webcam as long as the camera is functional. The latest version at the moment supports Windows 7, Windows 8.1, and Windows 10.
It requires Intel Core i3 or faster processor, 2 GB RAM, and broadband internet connection. For Logitech webcams, you can download the driver from Logitech Support.
