A way to alter ANSI font Mac
Experts,
I’m just curious about Altering Stuff. Is there a possibility that I can alter ANSI font Mac? Your suggestion and ideas would be very much appreciated. And also if there is such software to do so.Â
Experts,
Hello Mr. John,
You can alter the way output by using Colors and Fonts page of the Display World Configuration. It makes it easier to use.
On this window there are two buttons, Change Output Font and Change Input Font. Each will open a dialogue box to choose a font selection.
There are also check buttons. You can choose to display ANSI color, ANSI underline and ANSI Flash.
Please check the image.
Hope this would help you.
Thank you.
