The way to install Google docs android app my mobile
Hello expert, I am using a Samsung S3 android version. I have to install the google map and google drive for my android. Please can you suggest me the way to install google docs android app on my mobile?
Best Answer by Harrington Curtsinger
Answered By 0 points N/A #128628
Hello Tiffany A Toombs,
Google Docs is a very important drive where you can store your important files.
You can access important documents from all over the world via Google Docs.
You can also use Google Docs on your Android phone, but you must use the Google Docs application.
Download it here.
Now, download and enjoy it.
Answered By 0 points N/A #128629
Hi Tiffany, good choice of using a Samsung Galaxy S3 cell phone it is awesome, fast and easy to use. By the way you can use WiFi and  go to PlayStore Application on Samsung Galaxy S3 and search for a google docs application. Or you can use the internet to search and download an application that supports google docs. Hope I helped you best regards
Answered By 590495 points N/A #343659
If you have a compatible Android phone, you can download Google Docs on Google Play. The app is regularly updated and the latest version varies by device. The app is rated 3+. With Google Docs on your device, you can create, edit, and collaborate on documents with others using your Android phone or tablet.
Here are a few features:
  • Create new documents or edit existing files.
  • Share documents with friends and collaborate in the same document simultaneously.
  • Work with your documents anywhere and anytime even offline.
  • Add your own comments and reply to other comments.
  • You can stop worrying about losing your work because everything is saved automatically as you type.
  • Open, edit, and save Microsoft Word documents.
