Way To Fix Windowsupdate_8024402b
How do I fix windowsupdate_8024402b error while updating windows programs, is there any easy solution for this error?
The major reason for this error is irregular registry configuration.
So the easier way to fix this is by installing and running SmartPCFixer tool.
If that didn’t work, then it’s not that easy to solve it anymore.
• Go to administrator tool,
Find windows update service and stop it.
• Go to C: \windows\, now rename the SoftwareDistribution folder to something like SoftwareDistribution.old.
• Restart the windows update service.
• Check for windows update
• Now it will load all the updates.
• Now you can delete the file you’ve renamed.
