Way To Unblock Internet Access
I am unable to access a particular site. I think my internet access for that particular site is blocked. How to unblock internet access?
To unblock internet access the following steps must be followed:-
1. Go to Control Panel and then click on the Security Tab.
2. In the internet security zone of the click on the restricted website and then click on the button labeled sites.
3. Next click on those websites, which you want to access. On selecting the URL of those websites, click on the remove option. Then those websites would open without any intervention.
If you think you are blocked from accessing a particular website, one solution is to use proxy. There are lots of free proxies on the web. If you are using Opera, you can use an extension called SurfEasy Proxy. It is a proxy extension for the Opera web browser developed by Opera itself.
It allows you to mask your real IP address and geographic location and you can appear to be in the United States or some other dozen countries. It also allows you to avoid being tracked and browse the internet anonymously. It is also a great way to access websites that are blocked in your country.
Since it is an extension installed on the browser, it bypasses any firewalls you may have allowing you to browse the internet without limits. Another way to use a proxy on your browser without installing a plug-in or extension is to use public proxies such as these from Public Proxy Servers.
