Experts! I need some tips or suggestion. I just buy a netbook and to my surprise active desktop windows starter 7 is not supported. It will be great if someone may help me to get with this. Thanks so much indeed.
Ways to active desktop windows starter 7 possible
Visit the website of the manufacturer of your netbook. The mfg will probably have recommendations for you.
How much ram does the netbook have? How much can it have? What processor, what speed?
If you upgrade to 2GB, purchase the Windows 7 Home Premium upgrade version and install
Every Windows 7 installer contains all versions, but some are hidden due to the presence of an ei.cfg file in Sources folder. Extract ISO to desktop, delete that file, then recompile into ISO to create an All-Versions installer: Bootable ISO – Create from Installation Files
Now boot flash stick, select your licensed version, insert key from sticker. Activation may require robocall to MS to sort actual key from batch key given.
Find any missing drivers or favorite apps on the Support Downloads webpage for your model netbook, Adobe (reader, flash) and Java (runtime, free Ofc suite) websites.
