Rob Bell
Posted on - 07/27/2016
My laptop has been crashing again and again and is making a louder noise than ever. I feel that it must have got dirt deposited on its inside parts. Please help me out with the ways of cleaning dust out of the laptop!
Ways Of Cleaning Dust Out Of The Laptop!
Yes! There is a huge possibility that the symptoms you are getting like the crashing of system and louder noise must be because of the dirt deposited on the fan of the laptop. To remove the dirt out of there:
• If you are not familiar with using screwdrivers then, directly use the can of compressed air and bring it as close as you can to the vents or holes in your laptop body and blow out the dirt using the compressed air.
• If you are handy with screwdrivers, then you can open up the metal body of the laptop and depending upon the model, either the fan is being seen directly or you have to do some more dissembling of parts. After it is done, use compressed air to blow out the dirt more adequately and then assemble the parts correctly.
