Ways on how to activate your AVCHD to import videos
Good day! Can someone teach me how did you activate your AVCHD? I am having problems to importvideo files because the serial numbers asking only Unites States country. Thanks for the answer!
Seemingly the serial number you are using is fake or unregistrered. You can simply acquire one that is genuine and try using it again. Alternatively, you have set your regional settings wrongly or you might have submitted wrong information about your country at the time of registration. Change these feature and try again. If you have a firewall, disable it during the installation process since it miight block some files that are being installed.
Notifications
