Ways on how to attach JPG to MP3 files
Hello there! I just want to know ways on how to attach JPGto MP3 files? I have an iPod, and I want to see my images in it. Thank you for this!
There are two ways for attaching JPG to MP3 file. The first is with program called MP3Tag. It is a free program that allows you to add a JPG image to your MP3. It is easy to use and you will not any problems with it. The other solutio is to use iTunes. This program allows you to put an image on one song or on an entire album.
If you have MP3 files (.mp3) and you want to insert a JPG image (.jpg) in every MP3 file, you can use Winamp to do the job. It runs on Windows XP, Windows Vista, and Windows 7 and it should work perfectly on Windows 8.x and Windows 10.
Winamp is designed to run on Microsoft Windows only and has not been ported to any platforms or operating systems since the first version was released. To get the latest, go to Winamp 5.666. This is the latest and last version at the moment after it was discontinued.
After a change of ownership, the Winamp website is still up and running but no new version was released since 2014. According to winamp.com, a leaked version of Winamp 5.8 is getting its round on the internet. Because of this, they decided to make this new version available to the public with a little revision from the developer of Winamp itself.
They recommend that users download the version from the Winamp website to make sure you are downloading a safe and unmodified version. They also said that this version is not an ongoing project but assures users that they are working on a future new Winamp. To get the latest, download Winamp 5.8 Beta.
Now, to insert a JPG image to an MP3 file, load the MP3 file in Winamp. When the MP3 music appears on the playlist, select it then press Alt + 3 or right-click it and select “View file info”. In “File Info” window, go to “Artwork” tab then click “Load Artwork”. Select the image you want to use as cover photo then click “Open” to load the file.
When you are finished, click “OK”.
