co_darlene
10 points
Posted on - 09/08/2012
Code Guide (2004) states that Media Player, which is one of the widely used multimedia software, supports almost all types of multimedia including the use of subtitles. Aside from such, I would like to know if there are other ways on how to use auto sub media player.
Ways on how to use auto sub mediaplayer
Hello Co_darlene,
Actually there are many softwares which support all media types and also they support subs. Now, most of the media players are free and they support all the video types and sub types. You can use VLC media player, Gom Player, UM player and Media player classic as they are the most popular ne these days.
Hope this helps.
Hello Co Darlene,
As per my knowledge, the following software can fulfill your requirement. 1. Cyberlink power DVD 12 and 2. Aiseesoft Multimedia Software. This software has many fun, visible options. Â You can edit and mix your files, and much more.
I hope this software is satisfactory.
Maxwell Mark
Maxwell Mark
