Ways how to use Microsoft bits on a Mac please
Hi everybody, Please i need your help to know the tricks of how to use microsoft bits on a mac, it is urgent please. Thank you
Hi Sammy,
To know the trick of how to use Microsoft bits on Mac, you need to download the software of Microsoft bits on Mac from http://software.informer.com/, it is the website that offers free downloading from a trustworthy website. It makes you able to download large files. It also helps you to resume interrupted file transfers and it supports HTTP transfers.
Hi Sammy,
I have found you links that can help you know more about BITS it gives you an overview of the Network connections, the background, how the data access and storage works and its priority levels.
I will also give you a link that has the system requirements and the download for BITS 4.0.
