Ways to increase a weak internet connection
I currently managed to obtain an upgrade on the internet connection I have from my ISP. I have a 521mb and I know that it is a very weak connection for our age. But can anyone help me to get the maximum out of my connection? What I mean is that, is there a way that I can further increase the speed of my internet ?
Answered By 5 points N/A #189593
Internet connection is quite a troublesome thing if its speed is too slow. The OS increases this trouble to next level. Mostly, internet speed depends on your ISP’s package and speed. However, your system can be tweaked to increase the speed.
First of all, disable reserved bandwidth for MS products.
1. From Start menu, type “gpedit.msc” >> hit Enter.
2. Go to Computer Configuration >> Administrative Template >> Network >> QoS Packet Scheduler.
3. Double-click “Limit reservable bandwidth”.
4. Select “Enabled” from top-left pane >> change the value of “Bandwidth limit” to 0.
5. Hit Apply >> OK.
6. Restart your PC.
Also, try clearing cache of your browsers by pressing “Ctrl + Shift + Delete”, upgrade your browser to the latest version.
