Ways to install Acrobat flash player for Android
To all programmers out there,
Hello guys!
I just need your help regarding the ways to install acrobat flash player for Android. Some components of it is missing in my phone, so I need to install it manually. The problem is I don’t know where to begin. Can you help me by giving some reference links?
Thank you!
Answered By 0 points N/A #199161
Dear Tony,
You haven't specified the model of your Android Smartphone. As it is quite evident, Adobe Flash Player is not compatible with all Android devices out there. If your device falls in that range, there is no way you can install the Player on your phone. However, if your phone is compatible with the Adobe Flash Player for Android, you can easily download and install it from Google Play. You can also check whether your device is compatible with the software in the link I provided.
Regards
