Ways Of Dell Laptop Warranty Check Online.
Hello, Dell laptop has shut down and doesn’t open. There might be the software or hardware problem. I want to repair the device after Dell laptop warranty check online. How can I do it?
Visit the Dell support webpage to check the warranty status of your laptop. Enter the product ID or a Service Tag on the allocated box to help the web page to detect your device. It will show you the date of purchase and also the remaining warranty period. You can also speak to the customer support on 18004252067 to check the status of your warranty. The queries can be made to the retailers as well. There are multiple ways to check the warranty status.
If your Dell laptop suddenly shut down and doesn’t open, it probably turned off because of overheating. This is a pretty common scenario when using a laptop. This happens because the laptop has a very small frame which has limited space to allow cool air to circulate properly. It does have a cooling fan to allow the circulation of air inside but this is not enough.
It shuts down because the processor is too hot to continue operating. The machine shuts down automatically to avoid the risk of getting your processor fried and damaging it. One way of avoiding this is to install a cooling pad which adds extra support of making your machine cooler and continue operating. Check out the following cooling pads for laptops:
