Ways Of Editing A PDF File In Word Without Any Hassle.
I downloaded a file in PDF format and needed to do some editing on it. Can you tell me the ways of editing a PDF file in Word without any hassle?
The best way of editing a PDF file is converting it into Word format. You can do it by opening the PDF file in Acrobat and clicking on the Export tool. Choose MS Word as the export format followed by the selection of Word Document. Press Export and let the app to do the recognition. Give a name to the file and save it somewhere. Open and edit it. After finishing the editing, save the file as PDF from Microsoft Word, and you have the original but edited file again.
If you have a PDF file, you cannot edit its contents directly using Microsoft Office Word. I don’t think that’s possible. If you want to edit the file in Microsoft Office Word, you have to convert it first from PDF format to Office Word format either DOC (*.doc) or DOCX (*.docx).
To make it easier, there is an online service that allows you to convert PDF files to Office Word format. Visit PDF to DOC. It is a free online file conversion service that allows you to convert PDF files to Office Word format like DOC (*.doc) and DOCX (*.docx).
The service also allows you to convert a PDF file into other formats like text (*.txt), image format such as JPG (*.jpg) and PNG (*.png), and XPS to PDF. The service allows you to convert up to 20 PDF files. If you don’t want to install a PDF to Word file converter on your computer then this is the best option for you.
