Ways On How To Fix Google Error 404 Broken
I want to know ways on how to fix Google error 404 and that too urgently as I am unable to access Google on my browser Firefox and it’s really annoying. People please help me fix this.
To fix the problem you can try clearing cookies and cache of site you are facing problem. To do so-
1. Go to tools and then options
2. Then proceed to advanced and then offline storage cache
3. Then click the clear now button
4. To clear cookies go to privacy in options and then show cookies
5. Then remove the cookies.
This will help you fix the error.
A “404” error on websites indicates that the page or content you are trying to access is not available or cannot be found on the server. You normally see this error on a web browser when visiting a website. This can happen if the page you are visiting has been deleted, moved to a different location, or the HTML or PHP file was renamed.
In websites, this HTTP status code may appear in many different ways because it can be customized by individual websites. You might see it as “404 Error”, “404 Not Found”, “HTTP 404 Not Found”, “404 Page Not Found,” and more. If you are entering a link on the address bar of the web browser manually and you misspelled it, it will trigger a 404 error.
To troubleshoot the problem, check that your internet connection is working. Unplug the network cable from the network port at the back of your CPU then plug it back in. Open your web browser and visit a website then try clicking some links. Verify that your internet connection is working. If this doesn’t work, disconnect the other end of the cable from the Wi-Fi router and connect it back.
If this doesn’t work, restart your router. If your router has a power button, press it to turn it off then unplug it from the power for about ten to twenty seconds (10 to 20 seconds). Press any button on the router to discharge any leftover power or to power cycle. After this, plug the router back to the power and turn it on. See if this works.
