Hi, I was wondering how to download Windows PowerShell XP?
Ways To Download Windows PowerShell XP
Windows PowerShell is made up of object-oriented programs called cmdlets (pronounced as “command lets”), which can only run from within the Windows PowerShell command interface. Cmdlets perform a single task and are designed to work together to perform more complex task.
To download and install Windows PowerShell in your Windows XP machine, follow these steps: –
- Go to google and search for how to get windows PowerShell 1.0 page.
- Download and install .NET Framework 2.0 if it’s not already installed in already installed in your system.
- After .NET Framework 2.0 is installed, download and install the windows XP service pack 2 or windows PowerShell 1.0 version that matches your platform (x86or x64)
