Ways To Get Number To Go Straight To Voicemail In Steps.
Hello, how to get number to go straight to voicemail notify in brief for the better understating as well. Reply ASAP and thank you for solving.
Hello, to get number to go straight to voicemail you just have to dial 267-SYLDIAl form the mobile phone and it will directly redirect to the same. Also the ads will be heard and then redirect to the services. The same service can be used from the landline as well and then you can leave a message if want. Also for using the same services there are charges for the same i.e. approx. $30 will be cost to you. Also this kind of service in only in the US and not in other countries. But the service is only used for the postpaid services not for the pre-pad users.
