Jamalia Cur
Posted on - 05/30/2020
I often find it difficult to manage devices that each time I would have to go to the settings menu for opening the device manager.
I was looking for ways to create shortcuts to device manager which would make the access easier. I could easily create an icon on the desktop but I do not want to crowd my desktop.
Could you please suggest some ways in which I could easily open the device manager?
Ways to have quick shortcuts to device manager
One way to open the device manager is to use the Run dialog box. Its method which runs from Windows XP through windows 10.
All you’ve got to do is open the run dialog box by holding down the windows key and then the ‘R’ key.
Then simply type in “devmgmt.msc” .
You will be able to see a Windows similar to this
Or, if you are a command prompt person you could simply type in the command “devmgmt.msc” and that’s it .
