Ways to resolve VMWare Workstation 8 serial number error on PC.
I recently purchased the VMWare Workstation 8 and am trying to install it on my PC. This installation requires me to provide a VMWare Workstation 8 serial number, which, when entered, gives the following error – “serial number doesn’t match existing licenses.” How do I resolve this issue? Please answer as soon as possible. Thank you!
Best Answer by
Answered By 0 points N/A #330081
Hey there! I am assuming an error shows up when you enter the license key too. These are some corrective measures intended to eliminate the possible causes of the VMWare Workstation 8 serial number error.
First, ensure that you have a correctly licensed copy of Workstation. Check the product description to know whether the serial number will be supported on your current platform. In case you have, verify whether you have specified the serial number compatible and specific to your version of the Workstation. Hope it helped!
