Ways to thunderbird connection to server timed out and solutions too.
Now to increase the thunderbird connection to server timed out in stepwise for the better reference only and thanks for solving the same too.
Hey,
The thunderbird connection to server timed out is supported in many OS such as Windows, Mac and other OS too. It’s a browser used for searching the content over the Web only. Below shows the steps to increase its timeout is as follows:
• First open the thunderbird manually
• Then click for the tools > options
• Now go to the advance option in it
• Now click for the network and the disk spaces too.
• Now you can increase the timeout connections too from 60 to 120 as per the wish
• The problem is solved successfully.
