Ways To Turn On A Dell Laptop
The power button of my Dell Laptop is suddenly not working. I have repeatedly tried to switch on my laptop, but even after repeated try, I failed to switch it on. Can anyone tell how I can turn on a Dell laptop?
If the power button of your laptop is not working then it will be a bit tedious job to switch on your laptop. But though the way is a bit difficult you can switch on your Dell laptop using this way. Firstly you need to open the cover of your power button. For help regarding how to open your power button, you can refer to Dell website.
Once you have opened the power button then with the help of two small screwdrivers preferably the one’s, we use for a watch you should rub the oxidized contacts of the green electronic board as well as the corresponding antler-like contacts which are there on the case. And while doing this, you should switch off your laptop.
