We were unable to return you to republic wireless.com
While browsing republicwireless dot com, I got the following screenshot containing an error message that says,
Internet Explorer has stopped trying to restore this website. It appears that the website continues to have a problem.
What you can do:
Go to your home page
Try to return to repubhcwireless.com
We were unable to return you to republic wireless.com Internet Explorer has stopped trying to restore this website. It appears that the website continues to have a problem
I am using Norton Internet Security. I thought it might be a problem with Norton.
So I add the site as a safe one in the Norton. Yet I am facing the same problem.
Any suggestion or idea?
Please help.
Best Answer by Samuel Charsa
Answered By 0 points N/A #137470
Hello James,
I don't think the problem is Norton. The problem was probably caused by an add-on you recently installed.
Open internet explorer in "no add-ons mode" and see if the problem remains.
To know more about this follow method 4 from the link:
If this doesn't solve the problem, follow the other steps from the link above.
I hope this information has been of help to you.
Answered By 0 points N/A #137471
The problem arises only on Internet explorer 9 and it is caused when you have a Java Version 6 update 22 Or the Java version 6 update 23 installed on your system.
The other type of error that it shows is that Internet explorer has reopened a tab.
So install the latest version of Java to solve the issue. For more information visit here:
