Hey guys,
As we all know and use this weather app which comes as a widget in smartphones. The problem that my smartphone which is Samsung Galaxy Grand Neo has is the Weather app is showing error. I don't know what went wrong but I thought to delete the app but scared that if I do do then where can I download the same.
Weather app error in my Samsung Galaxy Grand Neo?
Hello Mary,
It would have been helpful, if you had mentioned what kind of error the weather app is showing. Here, I will give you the solution for the most common error the weather app shows about setting locations.
Use the following steps
(a) Go to Applications/Apps setting
(b) Select the weather app
(c) Select the setting option of the Weather app.
(d) Here change the Use Current Location setting to ON.
(e) Switch on your GPS and wireless options.
(f) Switch on and off the screen a couple of times, you should be seeing that the weather app is updated.
