Lance Hock
Posted on - 12/09/2011
I am not a pro when it comes to IT related issues. I wanted to download the weather network into my windows vista basic. I was able to download the program which includes weather eye and weather maps. The download was completed but when I tried to run the program, an error saying APPLICATION NOT FOUND comes out. I also get the same error message when checking my email inbox and any hyperlink in my system is not working. I am wondering whether anybody out there is having the same problem as mine. I presume maybe this has something to do with my operating system? Any idea
Weather network not working on Windows Vista
'Application not found' error that you are receiving could be because of various reasons:
First of all, your system settings may have changed, and thus affecting the proper installation of the application. So you may need to restore the system's default settings.
The application itself may be corrupt, or some important components are missing from the application. And therefore you will need to get another copy of the application online>>download it>>and then try installing it and see if it works.
And just in case you are trying to install it from an external USB device like a pen drive, then you have to make sure the pen drive is readable. Because if not then that is why you are getting the problem.
Regards
Thompson Locker
